Password reset
DerekNG
I forgot my Public Mobile account password. I tried too many times and now it is locked. I am just wondering what to do now
2 REPLIES 2
Meow
https://selfserve.publicmobile.ca/forgot-password/
The account might be only temporarily locked for an hour due to too many (5) attempts. You might want to wait an hour and try again.
HI @DerekNG   Wait an hour an try again
If you think you really forgot the password, try the Forgot Password link first.  Enter the email address to start
If you are unable to reset the password that way, then only PM CS Agent can help ,  Click on the Bubble or directly at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
  1.  type: Forgot log in information
  2. Click "Contact Us"
  3. Click "Click here to submit a ticket"
  4. you will then direct to another page to open ticket.
If you have problems submitting a ticket, you can also send a private message to the moderators (but this can take longer):
