Package upgrade
Bari
Will I loose any balance of International Minutes if I upgrade my package?
Bari
Quick reply, much appreciated
Bari
Thank you for prompt help
@Bari   no worry.  All minutes addon you purchased will stay with you after plan change.
Go ahead and make the change
@Bari  No you will keep all add ons you currently have and old rewards also . I just changed plans  and kept my add on and rewards . Check it out
