PUK
lipa1
Where do I & how do I unblock the PUK from the phone/SIM?
will13am
@lipa1 , based on past experience with members asking for a PUK code, if the phone is a Samsung product, that is an unlock code that Samsung can provide.  If if is a SIM unlock code then the moderator team can supply that.  The moderator team can be reached via private message using smartforms which is initiated by clicking on the ? on the lower right corner of the webpage or try using this link. The guided process will facilitate documentation of the issue or concern and the required resolution which will be submitted to the moderator team. Refer to this announcement link for additional details on smartforms and the ticketing system for moderator team interactions. If use of smartform brings no joy, then use the following direct link to private message the moderator team. Refer to the following knowledge base article for additional information on the moderator team.
brettster99
@lipa1
It is really hard for us to help you if we don’t know what phone you are using to help you find it. So do what @gblackma said so we can help you
gblackma
@lipa1 What's  the make and model of your phone?  Thanks.
