PUK code
MariahLG
Hello,
How long does it usually take the moderators to respond about PUK code
I have sent two messages so far over two days and have gotten no responce
13 REPLIES 13
Thanks @cin7...but I don't need any puk!!!
@surreyboz wrote:
@computergeek541 wrote:
@cin7 wrote:
@lorieux
In case you might still have the card from where you popped out your Public Mobile SIM handy, you can find the PUK code on this card.
I read a similar mesagge about this a few days ago. This isn't true.
Yeah like I mentioned in the message above your message. No Provider in Canada lists the PUK code on the Sim card or the Packaging of the Sim card
You're right.  Ii was not disputing your statement.
I was simply pointing out that misinformation has been posted multiple times by someone else about the printing of the code on the plastic that the sim card comes in.
surreyboz
@cin7 wrote:
@lorieux
@cin7 wrote:
@lorieux
surreyboz
@cin7 wrote:
@lorieux
No major Provider in Canada has the PUK code written on the Sim card.  A lot of Providers around the world do Write the PUK code on the Sim card or they Write it on the Packaging that comes with the Sim Card
@popping wrote:
@cin7 wrote:
@lorieux
There are two numbers with 2 bar codes.  Which one is the PUK?
No PUK code on the sim. The number on the back of the sim and on the barcode are both sim card numbers. The other barcode is just a model number i belive.
popping
@cin7 wrote:
@lorieux
cin7
@lorieux
@CS_Agent ...... @markr have been waiting one week please....
markr
I am also waiting for a reply. We have not been able to make calls for a week now. 😞
@CS_Agent wrote:
Hi @MariahLG,
We've replied to your private message! Please check your inbox 🙂
Thank you,
Syed
CS_Agent
Hi @MariahLG,
Thank you,
Syed
ShawnC13
@MariahLG wrote:
Hello,
@MariahLG, response time can be 24-48 hours.  If your phone is a Samsung I have read on here that people have had luck contacting Samsung directly and getting a Master PUK code.
Lieux
Patience @MariahLG it can take 2 Smiley Winkor 3 days
