02-01-2026 04:17 PM - edited 02-01-2026 06:47 PM
How do I get a PUK code for my locked eSIM when every option requires you to log into your account but that is not possible because I'm unable to get the required 2-step verification code due to the locked eSIM. Also can't log on to the forum so had to create another account just to post this with a secondary email.
Thanks!
02-01-2026 04:20 PM
Please remove your email as these are not private forums. Click on the arrow in the box and edit.
If you are able to log in, please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket. Enter CONTACT US into the chat and follow the prompts.
If you’re unable to log in to your account, please use this direct link to reach out to a CS Agent.
02-01-2026 04:18 PM
we are just customers like you, please remove your email from your post
for esim PUK, you need to ask PM support agent to help, you can submit ticket by direct message:
