PART 2
Jenjen78
I have a number ported which does not get texts, phonecalls
doesnt work
my old number from PM is now closed
i have no hotspot
i just want a number that works with a phone
doesnt work
i have no hotspot
Hello @Jenjen78 ,
Some trouble shooting for your to try:
*turn off your phone, leave off for a minutes, then reboot
*removing your SIM for a few minutes, then reinserting it
*go into airplane mode for a few minutes, then going back to regular mode
*reset network settings
*Is your phone locked? Contact your previous provider to unlock it for you. You will need your imei number, dial *#06# to get it.
*Check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
If still having issues after this and other suggestions contact Moderators for assistance.
To contact the Public Mobile Moderator_Team, there are two methods to reach them:
1 -  Faster - Click the bubble comment circle on the bottom right-hand side of your screen,
or use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower - Use this link to:
Private Message to Public Mobile Moderators (PM Customer Service Representatives)
doesnt work
Are you in the process to port INTO PM or port your number OUT of PM?
doesnt work
i have no hotspot
Pleae re-insert your old carrier's SIM card. You need to respond to a text message to authorize the number port. Also, those incoming calls will continue to go there until poritng is complete.
JK8
doesnt work
i have no hotspot
Are you a returning customer? If so maybe your port is not complete. I will email you the Telus porting team number. Check the envelope icon top right corner.
