P I n
IanP
How do you change your pin
hi @IanP you need to login My account on a browser and access this link
https://myaccount.publicmobile.ca/en/account/reset/pin
NDesai
@IanP Login to your self-serve account to change your PIN from your account settings.
fixin1
@IanP - In My Account > Profile (Or in Account section on the App) you will see your voicemail Pin and *611 PIN. If *611 PIN is not available try this link to change it:
