Over charged payment
Taniaguzman
I need To speak To an agent.i have been charged and i'm not using the service
2 REPLIES 2
@Taniaguzman
Are you signed up on PM?
Who is your current carrier?
Could we get more info of your problem?
@Taniaguzman   you decided to leave?  why charged and not using the service
PM is prepaid provider and will not provide refund.
If you just decide to not use the serve, or leave PM, you need to disable the Pre-authorized payments
If you just meant bought the the wrong add-on , then PM might be able to reverse the transaction and leave the money on your account for future renewal
If they did charge you twice by mistake  (as you said overcharged on your subject line), you can discuss with PM support via opening a ticket with them:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
