09-15-2023 07:13 PM
09-15-2023 08:31 PM
PM is on a 30 days cycle so it won’t fall on the 12th of each month so check your account when your renewal date ends.
Best to private message a CS_Agent to investigate on the switch plan renewal date.
09-15-2023 07:24 PM
@JMM1 with what you described, you likely had chosen Change Now option by mistake , but you can message support and confirm
