Outgoing Calls
ChaimLerner
Hi
My Outgoing calls suddenly stopped working
I'm still getting incoming calls and texts in / Out
But Outgoing calls are not working
any help?
@ChaimLerner wrote:
No. I have an Unlimited Plan.
Only Outgoing calls not working.
tried to restart my phone but didn't help
anything else to try?
@ChaimLerner did manually select the 3G / WCDMA ONLY network in your Mobile Connections area in your settings do anything?
Check for outages in your area:
https://www.telus.com/en/on/outages
https://istheservicedowncanada.com/status/telus
https://downdetector.ca/status/telus/map/
Perhaps perform a Reset of your device's Network Settings. This also resets Wi-Fi networks and passwords, cellular settings, VPN and APN settings, and connected Bluetooth devices that you've used before.
Iphone:
To Reset Network Settings, begin by opening the Settings app. Next, tap General -> Transfer or Reset iPhone -> Reset -> Reset Network Settings. and enter your passcode.
Your iPhone will reset network settings and restart itself.
android:
Find and tap Settings > System > Advanced > Reset options > Reset network settings.
If no other troubleshooting is working, contact CSA by methods provided by other members/customers already.
hi @ChaimLerner   try your sim card on another phone if you have one
if not, please open ticket with cs agent
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
ChaimLerner
hi @ChaimLerner there are many posts about voice problem in the last 2 days, but most have trouble with both inbound and outbound minutes.
Try reboot your phone.  Try to Reset All network and check if it works
@ChaimLerner are you on $15 plan with limited minutes??
 And is  that really just outgoing calls with the problem?  are incoming calls working?
There have been issue since yesterday for some people with both incoming and outgoing calls.
If it is just outgoing calls with issue, try to reboot the phone once.  If still fail, try to change to 3G only and see if it connects to the network at all with such settings
If both incoming and outgoing calls are not working, I suggest you to open a ticket with PM support and let them aware you are one of those, too
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
