Out of the unlock code in doesn't work
Tony26
I called rogers n got a unlock code when I summit the code it doesn't take I repeat n still nothing.. Any suggestions
2 REPLIES 2
Jarvar
@Tony26
I'd recommend contacting your previous provider (Rogers) just like @popping suggested.
It is their responsibility and their technical support is there to help.
Hope it works out.
popping
Contact Rogers again for the unlock code just in case they send you a wrong code.
Good luck
