Out of province add on
neo911
Hi,
If I have province wide plan and I travel out of province. I understand I can buy an addon.
- What is the cost of this addon ?
- any link where I can see the cost of all addons ?
- if i buy this addon i can receive calls and make calls to other provinces across Canada while roaming out of province ?
Kindly clarify
Cheers !
7 REPLIES 7
neo911
ok @srlawren got it ! big thanks.
srlawren
@neo911 one small clarification on @makkahn28's info:  the $8/200 minutes includes long distance numbers to any phone number in Canada or the USA, plus any incoming calls while you are outside of your home province.  The $15/400 mins includes that, plus calls to a list of international countries.  These add-ons do NOT include any service while you are physically out of the country, as PM only operates withing Canada and has no roaming agreements in US or internationally.  Also, they care not a substitute for picking a Talk option in your plan; they only work if you have at least province-wide calling in your plan.  Hopefully that helps.
neo911
ok. thanks @NDesai
@neo911 wrote:
can you also post the price of other addons listed on the self serve page ?
200MB for $10
1GB for $30
No other add-ons.
neo911
Hi @makkahn28. thanks.
$8 for the 200 Min Add-On
$15 for the 400 Min International ( Which includes Canada) Long-Distance Add-On
makkahn28
Yes, there are Add-On Long-Distance available
