Only two bars
Bordeau
New customer, iPhone 11 with eSIM. Can’t have more than 2 bars connection.
How can improve that?
1 REPLY 1
@Bordeau  2 bars does not really mean bad reception.  It is more the speed that counts
What speed are you getting? and are you connecting with 4G/LTE or 5G?
Depends on your plan, you should get around 3Mbps if you have a 3G plan, 50 to 100Mbps if you have a 4G plan or 100-250Mbps if you have a 5G plan
You can also try Reset network settings after a device reboot to see if the speed improves
