03-22-2024 12:37 PM
I have a solution!
If you recently updated your OnePlus phone and it's no longer sending MMS on Public Mobile the issue is with your "Access Point Name" or APN. You can edit the settings for the APN under Mobile Network Settings (maybe under "more" or "advanced settings").
Changing to an APN with the following settings has worked twice for me (had to redo after another os update):
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
Hope that helps! I got the answer from a chat agent here.
a week ago
Mettre les infos à jour marche pour mon OnePlus Open!!!
03-22-2024 01:01 PM
thanks @Brockmanatee
yes, we see similar advise already. Keep in mind for some people, simply updating the APN wont' work They might have to delete the APN and add a new one and enter all the fields agian
