OnePlus Nord N100 compatibility
cheemas89
Hi,
Does the OnePlus Nord N100 (Model BE2011) work with Public Mobile? Thank you!
cheemas89
I brought this for my dad, from my research it's the best in that price range and you get a free screen protector if you order from OnePlus.
Thanks @cheemas89,  yes, price is good for the spec.  I was debating to get this one or a Samsung for my parents
cheemas89
From OnePlus website, for $250.
@cheemas89   yes, from what @BeachNBeer shows, it should work very well on PM
where you got yours from?  Amazon? or you got it from overseas?
BeachNBeer
@cheemas89  .
It will work.
@cheemas89
Yes is will working with Public Mobile.
visit Here link to you review full information,
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
visit  Here link, to check it all Provider in Canada about compatibility with any device..
