07-24-2023 07:21 AM - last edited on 07-24-2023 07:25 AM by computergeek541
When I login my account, I choosed my phone is my trusted device so don’t need second step (send code) but then next time still ask me the code:((
where I could setup else ? Can I set up in my account like before?
Be honest, I like the old website much better than now:((
07-24-2023 08:11 AM
is that Chrome on Adnroid you are using? what Android OS you have?
I am using Chrome on the phone too. Which I might need to login again, it goes through login without needed 2FA again for me. And Chrome on Android does not have clear cache on exit option
07-24-2023 08:02 AM - edited 07-24-2023 08:03 AM
@Lhaha Sorry you can’t turn off 2FA like before . It’s annoying to have to enter a code all the time . I do to . But it’s just a code only slows me down by like 2 seconds . So not rally that big of issue at the end of the day
07-24-2023 08:00 AM
it works for me
what is your default browser on your phone?
Check it and make sure you don't have optino like "clear cache on exit" enabled.
I use google chrome
07-24-2023 07:40 AM
it works for me
07-24-2023 07:25 AM
@Lhaha wrote:When I login my account, I choosed my phone is my trusted device so don’t need second step (send code) but then next time still ask me the code:((
I've never once got the remember deivce otpion to work. I do suspect that this is related to web browser settings, so if cookiers ever get cleared, setting this won't work.,
