03-15-2024 07:18 PM - last edited on 03-16-2024 01:43 AM by computergeek541
Does One Plus 12r work with Public Mobile? anyone know?
03-16-2024 04:46 AM
A few people reported this phone has 5G and VoLTE on PM. From this thread: https://forums.redflagdeals.com/search.php?keywords=public+mobile&t=2671211
03-15-2024 09:10 PM
Yes, it does as long as 2 frequencies in 3G, 4G/LTE and 5G.
03-15-2024 07:49 PM
HI @tl2000
yes, your phone will work here, it has all the required bands
but you will be using 3G for voice and not VoLTE and it is not on PM's VoLTE shortlist
also, check if MMS work, you might have to manually tweak it for MMS to work, common problem with OnePlus thing
Yes, it is a great Android phone 🙂
03-15-2024 07:23 PM
@tl2000 - It will work with 3G calling but no VoLTE at the moment. But the LTE data will work for sure on PM.
So If you are going to the USA you are soon out of luck for voice calls because T-Mobile is shutting down their 2G network.
