Nunavut
Dalembath
Are you able to a local number for Iqaluit, Nunavut?
@Dalembath wrote:
Thankyou, actually the service is very good that's why I wanted to keep Public. Will just keep my Ontario #
Even if you have Canada-wide calling in your plan, other people might end up paying long distance fees to call you.
Dalembath
Telus/Public Mobile does not offer phone numbers anywhere in Nanavut.  Public Mobile will work there based on coverage maps, but that's likely because of the Bell Mobility presence in Iqaluit.
GinYVR
@DalembathYou can pick a 867 area code (Nunavut area code) by select NT-Yellowknife I think that's as close as you can get.
GR
@Dalembath  I don't believe you can,  on the list of pick a number the only thing other than provinces is Yellowknife
Triguy
I doubt you can get a phone# for Nunavut.   You probably need to select the closest city/town. You could choose your city and province to get an area code. You can also select the option to customize the last 4 digits of your number.
