06-13-2023 05:31 PM
Good evening
I did a number transfer yesterday and I'm still not able to receive calls
06-14-2023 09:21 AM
@Hiten already sent 🙂
06-14-2023 06:56 AM
I am having number transfer issue. Can you please share live agent number so they can re process.
thanks
06-13-2023 07:23 PM
In short, your number transfer request failed.
I just dealt with this. It is such a waste of time and Public Mobile is failing miserably at this. You'll have to open a ticket by using the ChatBot. Be prepared to deal with customer agent who won't adjust the billing period despite Public Mobile dropping the ball.
06-13-2023 05:49 PM
A critical part to porting is to receive a text from your old provider and you have to reply YES within 90 mins. If you are not receiving calls and text on your PM sim card, and only outgoing calls, wok then you might have missed the step and hence porting was not completed
There is a number to call to talk to live support, they can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
