Number transfer
jllb
Hello, had my number transfered and worked for a few days now does not work and when I try to transfer again it says that my phone mumber is not illegible and Public Mobile has assigned me a new  cell number.
1 REPLY 1
slusagm
you can still make call? just not able to receive calls?
Reboot phone and Reset network settings first
and ask PM to check and refresh the account
  Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
