Number transfer
Sabreshark1
I need a number transfer sent to my old cellular provider.
1 REPLY 1
@Sabreshark1
how long you have waited? is your service on the old carrier active? you can still receive calls and text on your old provider?
There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
