Number transfer issue
Brando-ottis
Switched from virgin mobile prepaid to PM last week and can’t receive calls or texts only from selected numbers of different carriers, their calls go straight to voicemail and I don’t receive any notifications saying I missed a call or text
2 REPLIES 2
will13am
@Brando-ottis , when you did the number transfer, was there a confirmation text sent to your Virgin service requesting you to confirm the transfer.  If so, did you acknowledge?
JRod
@Brando-ottis
Is it possible you have a do not disturb mode enabled? Also check your phone settings if you have silence unknown callers enabled. If it is on disable it.
