02-04-2023
12:26 PM
02-04-2023
02:44 PM
computergeek541
I am trying to port a phone number from another carrier. Public says to use enter a valid canadian phone number. I am. Where do I go from here?
Joining Public
02-04-2023 04:15 PM
Good to know.....many thanks...👍...
02-04-2023 02:45 PM
@FlutteringBy wrote:Your image shows that you are porting your number TO Koodo....not moving it to Public from Koodo...
The Koodo website may have just been used to check number porting eligibilty as if a number can be ported to Koodo, it can also be ported to Public.
02-04-2023 02:25 PM
02-04-2023 12:40 PM
02-04-2023 12:38 PM
@dpjkf You need supports help after activation to port from Koodo prepaid
- Get support by starting a conversation with virtual Chat box /SIMon. Click here
- you can send a private message CS_Agents by clicking here.
Watch for reply top of page to the
Right ( envelope image )
02-04-2023 12:37 PM - edited 02-04-2023 12:38 PM
@dpjkf for Koodo Prepaid, it is a different process.
you have to get a new number first temporary. Once account activated and calls working, then open ticket with PM support for manual porting help
Add reference:
https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
If you wish to transfer an existing numbering from Koodo Prepaid or PC Mobile, you will need to first complete your activation with a new number, then reach out to our Customer Support Agents here in order to transfer your existing number to Public Mobile.
02-04-2023 12:36 PM
02-04-2023 12:35 PM
@softech , thank you so much for the quick reply. Yes, I am using koodo prepaid. This is my first attempt.
02-04-2023 12:28 PM - edited 02-04-2023 12:30 PM
@dpjkf did you attempt activatoin already, failed and re-attempt a second time and then got that error?
if so, that would be the first attempt either completed or hung somewhere.
or are you Koodo prepaid client now?
Add:
please also check if your number is eligible to port into PM here (it is a Koodo site, but the result applies to PM as well)
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do
