11-27-2023
06:34 PM
11-27-2023
06:38 PM
computergeek541
I can't use my old number from Virgin because the account was in my wife's name and I want to put it under my name. Where and how would I be able to do that...thank you!
11-27-2023 07:12 PM
I did send them a message...thank you for the link. This is all new to me.
11-27-2023 07:10 PM
I've tried both and it ask the same question.
11-27-2023 07:06 PM
have you ever linked with your email also? perhaps you can try to get code from email.
11-27-2023 06:48 PM
@Bercor Maybe contact support to help you
send a private message To CS_Agents click
VVVVV Link below VVVVV
11-27-2023 06:46 PM
I can't even log in my account...keeps asking for a 6 digit confirmation number.says it will send it to my phone and when I enter the number,it says incorrect number.
11-27-2023 06:44 PM
@Bercor You just need the Virgin account number for transferring the number. I ported my phone number that was under another name as primary and had no problem, just had to give the account number, it didn't even ask the account holder's name.
11-27-2023 06:38 PM
@Bercor wrote:I can't use my old number from Virgin because the account was in my wife's name and I want to put it under my name. Where and how would I be able to do that...thank you!
This would be done the same as any other phone number transfer. The names being different doesn't present any barriers. You would only need to enter your wife's name on the number porting request form. The name on your Public Mobile account could be set to anything.
11-27-2023 06:37 PM
@Bercor You want a new PM phone number do it in your my account profile page
Change # on profile tabs
