02-16-2022 07:16 PM
Hi,
I've just transferred the phone number I was using on Public Mobile to another carrier but I did not want to cancel service with Public, only change the number associated with the account. Is there a way to reactivate? I'm not able to login using my usual credentials.
Thanks.
02-16-2022 10:00 PM
02-16-2022 07:46 PM
@Rai Officially, that is correct.
Although, some cases have been reported of charges to cards after ports in the past.
Keep an eye out on your credit card statement, or if you feel more comfortable confirming the card is removed and will not be charged contact Public Mobile Representatives (CSA) by submitting a message(ticket) to them here:
Private Message to Public Mobile Customer Support Agents (CSA)
02-16-2022 07:44 PM
So even if I was on Autopay I'll never be charged anymore until I choose to sign back up with a new SIM with Public?
02-16-2022 07:36 PM
Once you port out your old number, that is it…your account will be cancel immediately.
02-16-2022 07:26 PM
@Rai By default your account terminates when you port out. There is no way to reactivate the same account. This is the case on every carrier when you port out a number. You will need to activate another account if you like to stick with Public Mobile.
02-16-2022 07:25 PM - edited 02-16-2022 07:27 PM
@Rai - sorry, yeah, porting out of Public Mobile automatically closes your account, and rewards or Available Funds are lost, and you lose access to your Self Serve account.
Only way to reactivate, is to port back in. But you need a new SIM card, because you cannot use the one you closed out from.
EDIT: did you approve the port via a text yet on your Public Mobile SIM card?
IF not, then the account may still be alive. Just don't respond yes to the port....but since you cannot log in, I am guessing that time as passed.
02-16-2022 07:23 PM
No, sorry... once you have successfully ported out the number, your PM account is closed. This is the way it works with all carriers.
02-16-2022 07:20 PM
Hi @Rai
when you Transfer out your account with PM will be immediately close.
