02-20-2026
09:54 PM
02-20-2026
10:08 PM
computergeek541
Hello I transferred my phone number from Chatr and received a number transfer text to which I replied “YES” but the phone number hasn’t transferred.
I also noticed that my Public account states my transferred number online but my phone doesn’t recognize it (there’s no number associated with my public e-sim)
please advise
02-20-2026 10:00 PM
is your Chatr sim still working?
what you can do is to remove your Chatr sim card , or if disable the Chatr eSIM. Then make sure PM sim is set as Primary and enabled. Reset network settings after a device reboot and test to see if you can make and receive calls
if the PM eSIM still does not work, Check with PM agent. There is a number to call to talk to live support, they can providing you the porting update. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
But if you are unable to reach someone from the live support with the phone number I sent you, you can also message them here:
**After opening the ticket, please monitor your community inbox (envelope icon on the top right), the customer support agent will get back to you in sending a message there.
