Number Transfer Manually Out
ausrock
Transfer number manually out help.
I cannot access my old eSIM.
@ausrock
but you are transferring out? and you need the sim so you can reply the port authorization text?  message support for help if that is the case
ausrock
@softech
I’m leaving public mobile and my eSIM was deleted by accident.
@ausrock
are you asking how or do you have trouble porting out?
For How:
To port out, you start the process from your new provider
But first, make sure your PM account is currently active and you can receive text without problem.  Login to My Account and get the account number from Profile page https://myaccount.publicmobile.ca/en/account/my-profile
While you are at My account, you might want to also disable Pre-Authorized payment just in case.
Now activate your new line with your new provider and request to port a number. Provide them PM's account number as the porting information
this is critical:  Then still have your PM sim card in the phone, wait for PM to send you a text to confirm your porting request.  You need to reply YES within 90 mins
After you replied yes, you can put your new sim card in the phone and wait until you get incoming calls.  Once you are getting incoming calls, porting is completed.  Your PM account will also be closed at this stage (you will no longer be able to login to PM My Account after)
For having trouble:
Make sure your PM account is active and you can still receive incoming calls and text
Then call your new provider and ask them to re-trigger the porting request.
Wait another hour or two and you should receive the Porting Authorization Text from shortcode 4799 or 4800
If still not receive the text from PM asking you to approve the porting,  please open ticket with PM support using this direct link:  https://urlshortner.tiia.ai/Lc9xk8
Make sure that you respond to this text within 90 minutes. If you do not receive this SMS or you do not respond within the 90 minute window, make up to 4 additional attempts to send it. If you are still experiencing any difficulties, reach out to a Customer Support Agent
(Ref: https://www.publicmobile.ca/en/on/get-help/articles/porting-out  )
hairbag1
@ausrock
are you trying to port in to PM or out to new provider ?
