01-03-2026 12:56 PM
Hi Trying to do a new activation and number transfer from Virgin Mobile and th3 last step tells me that the subscripion did not activate. Please help as im in the middle of activating.
01-03-2026 01:00 PM
hi @OlegNL
try reboot the phone and relogin the app and see if it can complete the activation that way
Also, are you activating physical sim or eSIM? did you try putting the sim in the phone and see if it connects to PM?
but if same, ask PM support agent to check what was wrong with the activation and confirm the porting, you can submit ticket by direct message:
01-03-2026 12:58 PM
it is more related with activation than transfer at this porint.
please contact PM and ask them to check
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
