Num
Nicolas12
Hi I'm wondering if there is a customer service phone number if you dont have any plans with public mobile yet.
hairbag1
@Nicolas12
the Community Forum is where you should pose your questions to start...we can usually help before Customer Support gets to it. Give us an idea of your concern and we can suggest or direct.
hi @Nicolas12
PM has an online support only model.
So, if you have any issue with plan, you still need to submit ticket, but via private message.    So, you will submit  ticket by direct message:
slusagm
no number to call, but you can open ticket
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
