Nuisance Calls
BajaMx1
I recieved 39 nuisance calls yesterday and it's followed this same pattern over the last few weeks.
What can I do to block
2 REPLIES 2
Yummy
Number you see on display is most likely spoofed (and it could be legitimate) number. So if you block it at your phone then if REAL person (and not spammers) calls you will not get it.
Nothing you can do... PM does not control who calls you nor can block spammers.
If you do not recognize number, do not pick it up. Those who really need you will leave voicemail.
sorry @BajaMx1
nothing much you can do other than hang up and let it go to voicemail.  This is the issue everyone is fighting against, regardless of the carrier
you can use the phone feature's of not ring on unknown number (numbers not on your contacts), it will simply send those unknown to your Voicemail
