13 hours ago
- last edited
11 hours ago
DR_PM
Neither my husband or I can place or receive calls, but everything else works. Anyone else?
11 hours ago
something is wrong i can't call external numbers or check my messages only local calls works
11 hours ago
just bad luck, usually PM service is good
but it has widespread voice call issue. I think data still work.
if you like, download a VoIP app like TextNow and use it to make calls until issue is fully resolved
11 hours ago
yes seems to be an outage
11 hours ago
also going east, Quebec, NewBrunswick, Newfoundland. Think its safe to say phone outage canada wide.
Data and texting works, doing the airplane mode on and off seems to work for some.
Hopefully its back sooner rather than later. Thank you for all admins who are replying appreciate it 😊
11 hours ago
your concern is with Eastlink...this is Public Mobile. Give them a call to see if they can help.
11 hours ago
Yes I'm in Barrie, Ontario looks like widespread outage.
11 hours ago
Yes tried rebooting cell no luck. Widespread outage looks like. Thanks
11 hours ago
there is a big thread about the voice calls
try Reboot the phone, or you might need to wait PM to fix the issue
11 hours ago
I have switched to eastlink and its been nothing but problems. Being told my voice mail doesnt work by my doctor. Now im being told that when they try to call me it says call failed. Lastly when it does go through the voice quality is extreamly low. This is absolutely unacceptable .
11 hours ago
11 hours ago
not able to receive incoming or make outgoing calls in nova scotia
11 hours ago
11 hours ago
I cannot make outgoing calls. I am in Nova Scotia
11 hours ago
sounds like there's a network upset in many parts of Man, Ont and points east. Should be fix shortly.
11 hours ago
11 hours ago
11 hours ago
11 hours ago
11 hours ago
this has been reported and affects customers in Ontario and points east. Should be fixed soonly.
11 hours ago
11 hours ago
11 hours ago
My service in Toronto was down for a few hours this morning. It just came back up, however I can't connect to voice mail.
11 hours ago
@Ayala18 wrote:What’s pm mean
PM = Public Mobile
11 hours ago
In Ontario and not able to make calls, maybe incoming as well
11 hours ago
11 hours ago
Anyone else cannot make an outgoing call right now?
11 hours ago
What’s pm mean
11 hours ago
I am in quebec
11 hours ago
I am having the same issue
11 hours ago
