08-22-2019 02:37 PM - edited 01-05-2022 06:35 AM
08-22-2019 07:18 PM
@Adam1990 wrote:I bought and paid for a SIM card with a plan for Canada wide calling and unlimited texting but for some reason it not working
Where did you buy the card from? Did you go into a store like a walmart and have them activate a sim card for you?
Did you purchase online and setup your self?
08-22-2019 03:49 PM
08-22-2019 03:19 PM
@Adam1990Sounds like your SIM card was not activated correctly.. you will need to contact the moderators with this link https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Tell them what your SIM card number is, they will get back to you in about 48+ hours.
08-22-2019 03:16 PM
Yes it is unlocked when I go online is says the SIM is invalid and when I try and make a call it says I don't have the add on to do so
08-22-2019 02:42 PM
08-22-2019 02:40 PM - edited 08-22-2019 02:41 PM
Any error message on the phone's screen? Sim network unlock pin, emergency calls only, no sim card, etc.? If you log into your self-serve account, is your plan status stated to be "active"?
08-22-2019 02:39 PM
Go to Get Started at top of page to confirm if your phone will work here and if it's blacklisted somewhere .
