04-25-2021 09:53 AM - edited 01-06-2022 01:53 AM
I recently bought a Samsung A71, open box (online) , sold by Best buy (not any 3rd party), it worked fine for first couple of days and suddenly message coming as not registered on network. Checked with best buy and was advised need to check with provider. I am not sure hw to go ahead and totally lost. Hope someone could help me.. Thanks in advance.
04-27-2021 06:34 PM
You might want to look at the new Samsung A52 with the refund you got.
04-27-2021 05:53 PM
@Smanjari30 wrote:Yes, finally Best buy refunded me the full amount, they had no idea why it happened , they were saying that when it was shipped from the warehouse, it was unlocked and fully functional.
The only other reason one of the manager pointed out was , some body trying to make a fraudulent claim by messing with the IMEI #
Thank u all for the support 😌
@Smanjari30 nice to hear that you got refunded. Good thing you came to the forums as Public Mobile has an amazing community of fellow customers who are very knowledgeable and ready to help.
Have a nice day
RosieR
fellow customer
04-27-2021 05:42 PM
Yes they did refund 🙂
04-27-2021 05:42 PM
04-25-2021 03:22 PM
@Smanjari30 If Bestbuy is still being obstinate tomorrow, contact your credit card company to dispute the charge.
04-25-2021 11:31 AM - edited 04-25-2021 11:32 AM
@Smanjari30...
.(clipped this from their website)...
Do Geek Squad Certified Open Box products come with a warranty?
All Geek Squad Certified Open Box products come with full warranties, whether it's provided by the manufacturer or Geek Squad.
04-25-2021 11:00 AM - edited 04-25-2021 11:01 AM
@Smanjari30 : There may be methods to change the IMEI. There may be methods to unblacklist it.
But why go to the bother? The phone is new to you. If it was actually from BestBuy then they should be able to replace it. Then check the new IMEI of course. If it was from a seller on their site then that seller should and if no satisfaction there then escalate it up to BestBuy.
But I suppose doing all that is also a bother. BestBuy should be able make you whole. They're not a mom&pop shop.
04-25-2021 10:58 AM - edited 04-25-2021 11:01 AM
@Smanjari30 wrote:It clearly shows sold and shipped by Best Buy.. i will talk to them again and keep u posted.
thanks for your reply
There is NO WAY you should lose out in this case. If the online customer service won't refund or exchange, escalate it within Best Buy's corporate.
Request the formal escalation process - they will (eventually) advise you how to escalate a concern and when they find out you're serious about doing so, they'll make it right.
04-25-2021 10:56 AM
04-25-2021 10:47 AM
That's good advice, @BKNS27 , re the box IMEI vs device IMEI.
Possible seller didn't cross-reference what's on the box to actual device therein.
04-25-2021 10:28 AM
Yup, i figured it was, @Smanjari30 , i just didn't want to explicitly state that on my initial reply.
This is ALL ON BEST BUY to assist you with, if in fact it was a Best Buy product and not some seller using a reference to Best Buy within the ad. (which i really hope is not the case...)
04-25-2021 10:24 AM - edited 04-25-2021 10:32 AM
If the phone is blacklisted then Bestbuy sold you a stolen open box phone...bring it in for a refund.
Also check to see if the IMEI # on the box is the same as on the phone. The phone may have been swapped off of the box at one time.
@Smanjari30 : No! This is all on the seller. That IMEI has been blacklisted somewhere along the way. It is dead in Canada. Get your money back or an exchange. This is not on the provider.
04-25-2021 10:21 AM
thank u , tried it but no luck
04-25-2021 10:21 AM
I checked on that site it is showing as black listed... called Best buy and they told to contact Samsung which I did and they are telling to contact the provider .
I did the steps you said but still not working. I did factory reset, network reset but still the same.. the sim card works in my old phone
04-25-2021 10:06 AM
Check to see if the Samsung software is up to date by going into settings>software update>download & install>check to see if it is the latest version.
If it is the latest version then power off the phone, check to see if the SIM is seated in the tray and wait couple of minutes then power up the phone.
04-25-2021 09:56 AM - edited 04-25-2021 10:02 AM
Use the following tool to ensure the device was not reported lost/stolen, thus blacklisted:
Complete instructions on how to do this are included in the link below:
Check the Status of Your Device in Canada - DeviceCheck.ca
If it WAS added to the list, I'd be bringing up the issue with Best Buy for having sold a device which was not sold with a 'clean' history.
Alternatively, you may wish to remove the SIM card, gently clean the contacts, then reinsert it carefully into the SIM slot on the device, making sure it slides in firmly and is not loose. It's possible your SIM contacts are not making necessary contact with the phone's contacts.
