10-21-2021 09:08 PM - edited 01-06-2022 03:34 AM
HI there,
I activated my new PM SIM card with new number but I'm not receiving any verification code from WhatsApp or chapchat. I'm trying from last days.
Thanks in advance guys
10-21-2021 10:27 PM - edited 10-21-2021 10:38 PM
@softech wrote:
@computergeek541 wrote:
Does Whatsapp have the option from them to call you and read the code out verbally?Whatsapp has that option, I used that before to activate it on my current phone.. .. but OP said "tried the call feature on WhatsApp but can't ".. not sure why .
I didn't read that as being part the discussion about verification, but rather with the inability to make or receive Whatsapp calls. In any event, there shouldn't be anything unique causing the voice call from coming in that provides the code as that would be a regular phone call (not a Whatsapp call).
10-21-2021 10:24 PM
10-21-2021 10:22 PM
@HALIMACS wrote:
It can take some time for these notifications to occur.
Give it a few days and things should start functioning as they should.
Make sure the service provider has your new/updated phone information and within a week, they should start routing to your new number.
To my knowledge, there shouldn't be any delay for these types of text messages to be working/received when a customer takes a new phone number as in the case here.
The difficultiy with this type of situation is how the issue could eithe be at the Whatsapp end or at the Public Mobile and it can be difficult to determine which it is. Does Whatsapp have the option from them to call you and read the code out verbally?
10-21-2021 09:51 PM
Yah I can receive from other mobiles
its new service
10-21-2021 09:35 PM
@onkar1984 It might sound unrelated, but this is sometime missed and may cause your issue.
Make sure your Google Play Service is allowed to send SMS and make calls.
Go through your System App list and check the permission for Google Play Service and make the change accordingly
10-21-2021 09:29 PM
@onkar1984 at least for Whatsapp, it can call you with the code instead of via sms
are you friends able to send you sms and you can receive without problem?
and you said you picked new number and not ported old number, right?
10-21-2021 09:26 PM
I'm have been trying from last two days
10-21-2021 09:23 PM
@onkar1984 wrote:HI there,
How many days have you been trying?
See a related thread about verification codes with recent activations: https://productioncommunity.publicmobile.ca/t5/Using-Your-Service/Can-t-get-verification-code-to-my-...
You could also try to uninstall these apps, then reinstall them. Reboot your phone.
10-21-2021 09:18 PM - edited 10-21-2021 09:21 PM
