01-12-2024 12:32 PM - last edited on 01-12-2024 12:41 PM by computergeek541
I may have an uncompleted transfer, but I never received the message for the confirmation. I put in the right IMEI number details but then PM told me I put the details in "wrong" and that an associate would reach out. For reference I'm porting a number from a 7-11 pay per call top up.
I ended up swapping the sim cards too early and noticing the call and data worked, without knowing the text and voicemail would be down until I re-ported the number. Should I submit another ticket? Help! (This is my first time buying a plan 😞 so I was a little confused by the instructions )
01-12-2024 12:41 PM
also, 711 does not provide confirmation, they might not even send you the porting authorization text. The porting could take 6 hours. So, after you contacted PM porting team with the correct info, wait 6 hours and call 711 and check to see if they got the porting request and if they have processed it
01-12-2024 12:40 PM
@remicurial wrote:I may have an uncompleted transfer, but I never received the message for the confirmation. I put in the right IMEI number details but then PM told me I put the details in "wrong" and that an associate would reach out. For reference I'm porting a number from a 7-11 pay per call top up.
Yes, you need to open a ticket to get Public Mobile customer support agent retry the number porting. As for those text messages and voicemail messages, you should have access to them if you re-insert your old carrier's SIM card. The old carrier's SIM card needs to be in your phone to ansewr the text message to authorize the number transfer.
01-12-2024 12:39 PM - edited 01-12-2024 12:42 PM
Some notes about porting from 711
Once you sorted out with 711, you can contact porting team again and provide the correct info. Will send you the poritng team support number to your Community inbox
