03-07-2023 05:10 AM
I can make calls but not receive calla. New PM Sim card.
I put the card in another phone and the result is the same. Is this a defected Sim card. And if so, how do I get this problem solved.
03-07-2023 06:32 AM
you posted here as well: https://productioncommunity.publicmobile.ca/t5/Get-Support/Technical-issues/td-p/956578
Did you transfer/port from another provider?
If so and it has been over the allotted time to complete the port, submit a ticket with Public Mobile representatives (CSA) for help; click this link for issues with transfer/porting of phone numbers over to Public Mobile.
When the incoming calls stop on the previous provider’s SIM card and/or landline/voip account, that is a good indication the port is complete.
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
If this was not an issue with a port, Perhaps you are affected by this: https://productioncommunity.publicmobile.ca/t5/Announcements/Resolved-Service-Impacts/td-p/955119
Can you try your SIM into another phone? If calls still don't work Turn off VoLTE if you have a VoLTE enabled phone. If that does not work, connect with contact customer service agent for assistance.
03-07-2023 05:49 AM - edited 03-07-2023 05:50 AM
Did you respond "YES" to the port authorization request when porting the number here.
Is your old provider service account STILL active?
If it is, the port maybe didn't complete.
I will send you a phone number to call if that is the case, to check the number click on the envelope icon upper right.
