Not impressed
08-03-2019 04:32 PM - edited 01-05-2022 06:15 AM
08-03-2019 08:04 PM
08-03-2019 06:35 PM
08-03-2019 05:21 PM
@popping the lost stolen trick works if the account is active or inactive. If inactive funds need to be greater than plan cost.
08-03-2019 04:52 PM
08-03-2019 04:39 PM - edited 08-03-2019 06:34 PM
@Lynn62 wrote:I topped up and my phone NOT working
Did you topup after your account was suspended?
If yes, did you click on the re-activate link at the of your overview page after login?
If your phone still not working after clicking the link, is your account status active?
If no, send a private message to moderator for help.
If yes, try the lost/stolen phone trick to re-provision your plan features.
1. Login to your self-serve account.
2. Report your phone lost/stolen using [Plan and Add-Ons] --> [Lost/Stolen Phone]
3. Logoff
4. Wait 5 minutes and login again
5. Report your phone found.
6. Re-start you phone to provision your account again. i.e. enable all features of you plan again.
If this trick failed to get thing working again, you should send a private message to moderator for help. But the wait is up to 48 hours. Good luck.
Edit: Thanks for @mimmo info. The lost/stolen phone trick works for any account status as long as there is enough fund in the account.
