Not getting SMS messages
YACHTING-STAR
Hello,
I'm trying to login to a few different services, eg: banks, and using SMS 2 factor authentication, and I'm not getting the automated sent texts on my phone. As a new client, is there anything I need to figure for this?
Thanks
walker1
Why didn't someone else think of or say that, in different words?
Yummy
If you ported your number from other provider, consider it might take up to 2 weeks for 2FA to 'find a route' to your new provider.
I assume everything else is working as expected? Calls/SMS/Internet in/out?
walker1
If not, PM support is your best friend for help.
@YACHTING-STAR if you ported your number into PM, it is normal those system generated text like 2FA to take time before coming to your new provider.   Systems take longer to see the new "home" of your phone number and route the text correctly.  Some systems also put that delay on purpose for security reason to avoid SIM fraud
So those text should start coming in the next few days.  In a week, they should all be ok
RossN
@YACHTING-STAR hi because of security measures in place from the banks and other companies your are getting the codes from, it can take up to 10 days for things to start working again, in some cases you may need to contact them to get things working again
walker1
@YACHTING-STAR wrote:
Hello,
Thanks
@YACHTING-STAR
After activation, those take about a week to work properly.
It's a security thing and those systems need to learn your new location, since you moved to a different provider.
