12-29-2023 11:44 PM
Hello,
I changed my plan in November and up til now I haven't been able to use any of my data. Any ideas what I could do to remedy this?
Thank you
Service
01-03-2024 11:34 PM
to update Carrier Profile:
Tap Settings > General > About. Follow the onscreen instructions to install your carrier update
Also, Please make sure you update your iOS as well
01-03-2024 11:27 PM
I have an iPhone 14. How do I update the carrier profile?
12-30-2023 09:22 AM - edited 12-30-2023 09:22 AM
Ensure:
- data toggled on
- no data limiter is set on device
- ensure data allotment hasn't been exceeded
- try your PM SIM card in another available device to see if data functions.
- if all above and other suggestion doesn't get you going, contact a customer support agent
To contact a Customer Support Agent, send a private message to them by clicking here. You’ll need to be logged into your Community account for the link to work.
Watch for their response in your Community private mailbox which will be indicated by a number on the small envelope icon to the left of your Community avatar, or tap your Avatar down in Messages.
12-29-2023 11:47 PM
Android or iPhone? Brand and model?
iPhone: Update Carrier profile first, then Try Reset network settings, try changing your network to 4G/LTE and test
Android, Try Reset All networks. Try changing the network mode to 4G or LTE.
![](/skins/images/C206B3E09108DC4A8294A110EB9CCA46/responsive_peak/images/icon_anonymous_message.png)
