11-06-2022 01:22 PM
When I login to my account it shows "the page is expired ". Why? All credentials are correct. Where is my account located?
My Account
11-06-2022 03:03 PM
When I get the "the page is expired ", it usually works on the second login.
My workaround to page expired or 404 error is to logoff every login session manually. Don't let the login session automatically due to inactivity,
11-06-2022 01:58 PM
Have had same problem and tried above solutions including entering info manually...and trying on a different device. Sometimes I get in and sometimes not. Most reliable is to open my account on my desktop PC. It's really frustrating. Would love to know how to fix this.
11-06-2022 01:38 PM
I had the same thing. If you are on your phone and you select for google to automatically input your info, it will automatically also press the sign-in. If you then hit the sign-in button as it's loading, it will show the pahe is expired page. That was what was happening to me. Try giving it some time for the page to load?
11-06-2022 01:32 PM - edited 02-17-2023 08:37 AM
Hi @juliaribk you can also try to press Back and Refresh and relogin, it might work
you can try with clear cache and restart browser
Or Private/Incognito mode, or a different browser
11-06-2022 01:24 PM
@juliaribk hi try using a different browser in private or incognito mode try to sign in again
