yesterday - last edited yesterday by computergeek541
Ordered sim card and started subscription a few days ago.
Received card yesterday, put the sim in. Can't make calls. Gives the subject line when I try.
yesterday
Yeah. Switched it over hasn't changed anything so far.
yesterday
did you use the app to update the sim card number?
yesterday
HI @KenBDusty
you need to use the app to complete part 2 of the subscription (putting in sim number and choose phone number/porting)
Please download PM app and login. In case you have trouble logging in, support agent can help.
you can submit by direct message:
