11-28-2016 12:09 PM - edited 01-04-2022 01:19 PM
My phone's SIM slot has a broken PIN and the 3-in-1 PM SIM doesn't reach down to the broken PIN. My old Fido micro SIM was only the 1 size (micro) and it did work because the contacts reached the broken PIN.
Is there any way to get a PM micro SIM that is not a 3-in-1?
08-07-2018 07:49 PM
@jclaydon2018 as long as you didn't snap or warp the adapter when pushing the nano SIM out of it, you should be able to push it back in after retrieving it from your phone. Be very careful in that extraction--I've ruined a phone's SIM slot one time doing this, making it unusable for cellular use.
08-07-2018 07:23 PM
If you got the 3 punch card and accidentally punched the smallest size when you need the middle one, can you put it back into the adapter or do i have to order a new one.
Of course, i will have to get the nano out of my phone first.. wish me luck lol
12-05-2016 12:40 AM - edited 12-05-2016 12:43 AM
I know that many people prefer these triple punched sim cards because they allow for easy switching to phones that use different size sim cards. It really is a convenience thing for the customer, as well as for Public Mobile because they only need to carry one type of sim card.
However, there are disadvatages for these multi-sized universal sim cards.
For the OP, he/she finds that since the sim card slot in the phone is slightly damaged, it is more tolerant to how the true micro sim cards are manufacturered (ie. usually larger electrical contact size compared to nano).
Also, I personally find that that the single-sized sim cards are a better fit in many phones.The possible extra possible bumps and ridges along the cutouts can actually cause the sim card to get jammed in the slot. The smaller sizes do also sometimes get loose and fall out of the larger sized cut-out unexpectedly. It can be more of problem especially on phones that use a tray that gets ejected, with such a sim card jamming would mean that you'd likely have to disssemble the phone. I'll admit those situations aren't that common but it does happen. Those types of things are the exact reasont that some phone manufacturers use to warn again using sim card adapters, and some even go as far as saying that if one of these gets stuck in your sim card tray, you warranty is voided.
Using a sim card that is cut only to one size is less problematic. But we'll likely never go back to those days because of the convienience of one-size-fits-all.
12-04-2016 11:04 PM
12-04-2016 01:29 PM - edited 12-04-2016 01:30 PM
@psmching https://www.amazon.ca/OnlineBestDigital-Adaptor-standard-Adapter-Iphone/dp/5891122952/ref=sr_1_2?ie=...
Its kind of cheaper then the a new sim card
but not by much. It will probably be better to buy the new sim cards that PM gives which are a 3-1 SIM. You will get a sim adapter included that way.
12-04-2016 01:23 PM
11-28-2016 04:49 PM
That's all the 3-in-1 is already... I tried another one I had laying around (for Roam Mobility) and it has the same issue. I think the problem is that the contacts on the nano SIM as so small it doesn't reach the broken PIN, whereas a "full-size" micro SIM would.
11-28-2016 12:11 PM
you could get a SIM adapter? I have a nano sim adapter that turns it into a micro
