Nokia 3310 having issues
Tman
Hi all I have a Nokia 3310.
The issue is that I often have phone calls go straight to voicemail when people are calling me, even though I am in service range and even in the same room.
What do you think?
Potentially I was thinking that somehow I may have blocked long distance calls but I don't think there is a setting for that.
1 REPLY 1
gpixel
@Tman unfortunately that phone doesn't work for public. it's too old and doesn't support the correct frequencies.
* nevermind... apparently there is a new 3g version
https://www.google.com/amp/s/m.gsmarena.com/nokia_3310_3g-ampp-8876.php
if you have a dual sim version try using the other sim slot
