No service
Timgardner
I have had very little service all day.  It is coming in and out with no more than one bar.  I am in Lambton Shores, Ontario.  Is there problems in this area?
NormanWalsh
I strongly suggest cell phone booster. PM me for more details.
Timer
@Timgardner
no report in your area ,  Check the status of service outages
can you do rebooting device....or tried your SIM card in other device.
NDesai
@Timgardner No outage report in that are it seems. Have you tried rebooting your device and see if that helped? Do you know anyone else on PM/Koodo/Telus having the same issue? If not, likely a fault with your device.
Hello @Timgardner
Check for outages in your area:
https://www.telus.com/en/on/outages
https://istheservicedowncanada.com/status/telus
https://downdetector.ca/status/telus/map/
Other troubleshooting to try:
  • restart your phone
  • toggle into and out of airplane mode
  • remove the SIM card and try it into another phone to see it if works
  • perform a Reset of the device's Network Settings
If issues persist, submit a ticket to CSA for assistance.
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them found here:
