No service
05-27-2022 08:59 PM
I’ve paid for my plan and when I check self serve everything is normal and paid, but i have no data / phone number / service as if i never paid my plan, help!!
Service
05-27-2022 10:47 PM
Did you port your old number over to PM?
If you are, did you leave your old SIM in your phone and replied to the text to confirm you are porting over to PM?
05-27-2022 10:43 PM
@meara - have you recently activated with Public Mobile?
Could your phone be locked? If so, contact the previous provider to unlock it for you. You will need your imei number, dial *#06# to get it.
Perhaps check if your phone is not blacklisted, check here: https://www.devicecheck.ca/check-status-device-canada/
05-27-2022 09:03 PM
@meara did you just join PM?
If so, try to put your PM SIM in another phone and see if it works
And what error do you see on the phone? SIM not provisioned? No Network? NO SIM?
If you got any of those messages and PM SIM not able to use on another phone, try to open ticket with PM Support, it could be just sim provisioning problem
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
05-27-2022 09:03 PM
