No service
AliyaH
I just activated SIM, paid for plan, my google pixel 6 phone showing public mobile however no service no network, tried everything, not working
AliyaH
Thanks everyone a cs agent helping me
@AliyaH  - I hope the above advice fixed you up, and you are now with service?
If still issues try to perform a reset of your device's network settings with the Public Mobile SIM card inside.
Otherwise...still problems, submit a ticket to CSA to check on your account's activation.
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them found here:
JL9
If it is showing Public Mobile, it could just be the simple steps @softech laid out. If none of those work you can open a ticket with a CSA, or private message "CS_Agent" here on the community (envelope icon in the top right)
@AliyaH
Try to reboot your phone one more time.
if fails, try to reseat the sim (power down, take sim out for a minute before putting it back to the phone)
if still fails , try to put your PM SIM in another phone if possible to see if it works there
also, check if your phone is blacklisted, just in case:
https://www.devicecheck.ca/check-status-device-canada/
