No service
HopfU
I have no service despite them taking the funds from my account. Anyone have any suggestions?
@HopfU  - okay, Active account status. Good to know.
Are you a new activation here? did you port over a number from another provider?
*Is your phone locked? Contact your previous provider to unlock it for you. You will need your imei number, dial *#06# to get it.
*Check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
HopfU
did not help
HopfU
when i call 611 I get a list of things that are of no help, and my account says active
@HopfU  - does your account status in self serve or by calling 611 say ACTIVE?
If so, try one or more of the below:
*turn off your phone, leave off for a few minutes, then reboot
*removing your SIM, then reinserting it
*perform a reset network settings on your device
If the status is Suspended try adding a $1 top up manually to your Available Funds balance, then can you resume/reactivate services? If changed to Active, then reboot your phone.
HALIMACS
@HopfU
What do you hear when you dial *611?
Also, log into your self-serve account, what's showing in upper left for status?
hairbag1
Try toggling Airplane mode ON...then OFF.
Let us know if that helps.
