No service
MAKOHAGOD
I purchased and activated my new sim cart and my phone number is xxxxxxxxxx but when i inserted the card in my phone Tecno Camon 16 S. there is no network signal. however when i tried it on my friends phone the card worked perfectly.
Could you help unlock my phone?
edited by computergeek541: phone number removed
8 REPLIES 8
@pkaraa wrote:
check settings here
https://www.howtogeek.com/710873/how-to-reset-network-settings-on-android/
If the SIM is working in another phone then probably your phone is locked.
It has already been established that the phone is essentially incompatible with Public Mobile. The device is entirely unable to make or receive phone calls at Public Mobile.
pkaraa
check settings here
Yes, PM needs
3G UMTS/W-CDMA/HSPA: B2 (1900) and B5 (850)
4G FDD-LTE: B4 (1700/2100 AW1), B5 (850), B7 (2600), B12 (700), B17(700)
but your phone has
3G Bands   HSDPA - 900 / 2100  <- not compatible at all
4G Bands    1, 3, 7, 8, 20, 28   <- only band 7 works on PM
you really need another phone to be used on PM (as well as Koodo and Telus and Bell)
@MAKOHAGOD
can you try to reset network settings on an Android device
  1. Open the Settings app on your Android.
  2. Scroll to and tap either "General management" or "System," depending on what device you have.
  3. Tap either "Reset" or "Reset options."
  4. Tap the words "Reset network settings."
   or visit  Here link,
and go Changing APN Settings On Android device
click Here link,
and Reboot your phone.
what is mean for Rebooting the phone means to turn off your phone about 2 minutes and turn it back on.
@MAKOHAGOD   It looks like your phone does not have the required bands for 3G network on Public Mobile.  if that is the case , your phone won't work for voice here.
Even for LTE, your phone only have some bands and not all that works here
 @MAKOHAGOD : The phone doesn't appear to be compatible with this place.
JK8
@MAKOHAGOD wrote:
I purchased and activated my new sim cart and my phone number is xx but when i inserted the card in my phone Tecno Camon 16 S. there is no network signal. however when i tried it on my friends phone the card worked perfectly.
If your phone is locked you need to contact your previous carrier to have it unlocked.
@MAKOHAGOD
remove your personal information in community site the are all customer like me and you, you can't post any personal info.. go to your message at edit reply. and remove it..
update @MAKOHAGOD
and if you try to test your SIM card in another device and is working then your device issue.
