09-21-2020 08:46 AM - edited 01-05-2022 03:58 PM
Yesterday I noticed I lost service with Public Mobile. I have tried to restart my phone, restart network settings, remove and put back in my SIM card and nothing worked. It was working fine on Friday and Saturday. I have the iPhone XR.
I did update to iOS 14 not sure if that had to do with anything and I noticed there’s a new option now “add your cellular plan” and you supposedly scan some sort of QR code from your service provider. Any help would be appreciated thanks!
Service
09-21-2020 02:46 PM
Turns out the sim number in my phone did not match the number on my account. The mod got back to me and notified me that someone had my sim swapped and it was a fraud pattern.
Thank you so much to everyone for their help!
09-21-2020 10:59 AM
Please also check to see if your phone has been blacklisted:
https://www.devicecheck.ca/check-status-device-canada/
If not, then the issue is likely related to iOS 14.
You may opt to restore your phone:
https://www.macworld.com/article/3564808/how-to-downgrade-from-the-ios-or-ipados-14-beta.html
09-21-2020 10:17 AM
login to your self serve account and click on "change sim" make sure the last 4 digits match the sim card in your phone. if it doesn't match then someone is commiting fraud.
contact customer support mods
click on the question mark chat bubble to the bottom right of your screen
type "security or identity fraud issue"
(use the chat bubble options, then click "submit a ticket, click me" option)
*login using your community account
make sure to check your inbox(top right corner envelope icon) periodically, for a response
09-21-2020 09:49 AM
Try the following :
Airplane mode on/off a bunch of times
Manual Public Mobile network selection
Turning the phone off/on many times
Removing and re-inserting the sim card
Try putting the sim card into a different phone to see if you have service available.
09-21-2020 09:40 AM
I’m on the the $50 plan, can only text through iMessage (wifi)
09-21-2020 09:25 AM - edited 09-21-2020 09:25 AM
@sincerelysammy1 wrote:says call failed any my account says it’s active
Are you on the $15 plan? If so, maybe you used up your 100 minutes?
Are you able to text in and out?
09-21-2020 09:16 AM
Could you please try it in a friend's phone that works with pm network for sure. It may be the phone
Can you also let your friend try his/her sim in your phone
09-21-2020 09:13 AM
09-21-2020 08:57 AM
Hello @sincerelysammy1 ,
What does is say when you call 611 OR sign into your self serve My Account?
Does it say: Active, Suspended, Expired, etc. STATUS?
