No service
Soyoung83
Hello,
The service has been down since around 4pm last friday.
I tryed everything with chatbot and article..
I don't know what happened, but it's causing me a lit of inconvenience.
just for your reference, the payment was automatically processed on my credit card on the 16th.
2 REPLIES 2
slusagm
Did you check your My Account? Is the service active?
Check if any outage in your area as well
https://www.telus.com/en/on/outages?linktype=ge-footer
Last, ask PM to help.  Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
Socrates8567
@Soyoung83 wrote:
Hello,
Try restarting your phone. Try going into your network settings and reset them and reboot.
Check your account and confirm the payment went through. Try your sim card in a different phone.
If all that fails, reach a csa via this link and get them to find out why.
